disable sflow ports
disable sflow ports port_list
Description
Disables sFlow statistical packet sampling and statistics gathering on a particular list of ports.
Syntax Description
port_list Specifies a list of ports.
Default
Disabled.
Usage Guidelines
This command disables sFlow on a particular list of ports. Once sFlow is disabled on a port, sampling and polling will stops. If sFlow is disabled globally, all sampling and polling stops
Use the following command to disable sFlow globally:
disable sflow
The following command disables sFlow sampling on port 3:1:
disable sflow ports 3:1
This command was first available in ExtremeXOS 11.0.
Platform Availability
